Custom Bits made from Bullet Proof polycarb material- See through!
Jahay
Custom Bits made from Bullet Proof polycarb material- See through! - 04.12.2011, 06:17 AM
As some of you know... im blinging out my savage with anodised parts and custom bits...
I wanted to show off my internals from below as my ESC plates etc will block my view of my centre diff etc from above...
So...
I met a guy who makes BulletProof Windows from high grade polycarb meaning they are virtuarly indestructible... Anything 6mm and over is considered Bullet Proof
This is my 2mm skid plate.
He can make them to any dimensions required
He even makes shock towers from 8mm material as well as other bits and pieces
He will make what ever you want as long as you send a template to work from and he will then send your template and finished item back to you *:P
They are even experiementing with thicker material and chassis....
