Jahay
04.17.2011, 05:18 PM
Thanks Dot... It is a bit of a hybrid now... I just want to take what i believe are the toughest areas of trucks and truggys and make a fast solid RC... more importantly, just be fun to build
Sparky... The chassis is based on the GCM Desertboy-17 chassis. But as this is my second one and i needed a custom one built so i could make my own areas for mounting .... Chris at GCM kindly offered to make me my own chassis to my preference, as it was my second one anyway.
Definitely hit chris up if you want something special!
anyway
I have been very busy this weekend with some DIY work... so not much time for the savage... plus im waiting on some solder and flux...
Anyway had an hour to fiddle today...
I have realigned the diff mount correctly now...
I just wanted to work on the wire mess that could occur if i dont get this right... So i wanted to see where everything would sit...
Some Wire Mesh to protect wiring.. .
BTW it isnt finished yet... So not all ends finalised
Black Mesh on Motor Wires
How ESC & Motor wires will eventually connect when i finish soldering of bullets.
How everything looks from below with the BEX and RX Case installed. _ servo wires obviously not pictured
Note the Wire Stay Holder at the front of the RX Box built into the plate. (THANKS DEJAN)
All Chassis drilling done and how it looks with Battery Box Mounts.
And One more
