04.17.2011, 10:46 PM
I checked the idiot forum; 166mm (long ) x 49.5mm ( wide ) x 25mm (tall ) fits fine apparently, may just need to make a little clearance depending where the wires exit the pack- you may also need the extended hold-down for taller lipos- part #5827x I believe. 59mm tall lipos sound a little on the big side, you may have some issues- a lighter can be used to stretch the plastic hold-down over the battery though if all else fails..
