Thread: RX8 on fire
josh9mille
josh9mille's Avatar
04.18.2011, 09:39 PM
Originally Posted by TekinTeamMgr View Post
Ideally we prefer to see 30c cells minimum. Low cell discharge can create a large ripple current spikes that can over work the systems and cause a failure. I of course can't say this was the case in your situation without seeing the unit first.
6000mah 25c lipos are 150 amps, more than enough, IMO.
Originally Posted by freddy View Post
next time you should buy the 4000mah 30c, can take alot higher amp draw(becouse of higher c rating) and even better its cheaper.
Actually that would be less than the batteries he was using, it would only be 120 amps
Remember C rating is not everything!
