brian015
brian015's Avatar
04.20.2011, 11:43 AM
Originally Posted by ikpthegame View Post
your a little off, heres what i got, i used the 5b tires since thats what hes got from the looks of it
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 19
Total Voltage: 22.20
Motor KV: 1580
Tire Diameter (inches): 5.311
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.53 : 1
Total Ratio: 8.35628 : 1
Tire Circumference (inches): 16.68 inches (423.8 mm)
Rollout: 2.00:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 66.32 mph (106.54 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Yes - they are 5b tires - but they are larger than 5.3 inches (the tires you used in the calculator are Savage tires - not 5b). My 5b bowties are 6.8 inches. So I guessed a little less than that for his tires.
