Manne
04.23.2011, 12:14 PM
scarletboa:
Yeah I thought so too but it was fine I have now sucessfully driven the truck four packs since the Heat incident. The motor is just too small, IŽll try the 2200kv but I doubt it will handle my driving any better in the sandpit..
IŽll figure it out.
Now I have another problem I keep bending the motor mount plate forward ( so the gearmesh gets to tight ) when I do my 17feet high nosedives So I will try to moke up some kind of brace, I think IŽll need atleast a 5mm thick motorplate to not bend it... It feels easier to just make a brace
The motormount have flexed so much that my pinion rubbed my recieverbox Thas is ALOT of flexing IŽll post pics later on
Also, I think IŽll go with rpm a-arms for the front and stock for the rear, Since IŽm only bending dogbones in the rear. Or maybe IŽll try rpm all around and see if the dogbone situation gets worse, ItŽs totally okay as it is right now, they only bends slightliy in the rear, nothing to be worried about.
IŽm actually amazed that they arenŽt bent more since the dogbones are almost bottoming out in the diffcups/outputs due to the bad machining of my Integy hubs.....And I have catched Major air and landed perfect for bending dogbones countless times.
Soo far, GREAT truck, It has already taken twice the beating that my revo build ever managed to take.
