DrKnow65
DrKnow65's Avatar
04.24.2011, 01:26 PM
RPM doesn't effect temps as much as load.
I.e. a motor pushing 1000watts at 60k will run cooler than a motor pushing 1500watts at 30k.
The more RPM you spin the less gear you have to run to get the same top speed, so less load.
I think the Neu's perform very well with a top RPM of 45-50k.
If you spin the motor to a max of 30k you end up gearing so high that there is an excessive load...
