Thomas Porfert
Thomas Porfert's Avatar
04.25.2011, 03:00 PM
Originally Posted by outlaw View Post
Thomas, if you want a "similarly heavy short course truck"
My RC8 to SC10 4x4 conversion would be perfect
It is about 7 lbs incl. a single 2S Lipo
Just had another testday
max temp was 75 degree C without fan and about 35 degrees C ambiente
I love this motor....
Well, we kind of wanted to test this on a short course truck since that what is designed and intended for. It would probably work in a 1/8th on a conservative setup, but that won't be the intended market. We want to hit the racers on bigger tracks that are required to run 2s and where the 1410/1Y will overheat and the 1415/1Y won't produce enough speed on 2s.
Thomas Porfert
Tech Support
