I'm a fan.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
I'm a fan. - 05.01.2011, 04:57 PM
I'm a fan now. Your work is very interesting, and I like the way you think with regards to rigidity, strength, and stability. This rig is going to turn out really solid if you keep moving in the same direction you are right now. Keep up the good work Bud. It's too bad that there is not an easy way to replace the bulkhead/diff setup altogether. Isn't there an aluminum upgrade for those diffs?
SUPERMAXX YOUR LIFE.
