Gustav
Gustav's Avatar
03.19.2006, 07:37 PM
This isn't really a problem,you just need a nitro style sliding brake linkage,so the servo will move in the throttle direction but the brake linkage won't.Then just adjust the brake side of the throttle channel to adjust your brake EPA.simple.you can't reverse the channel though,you'll just have to mount the servo arm on the other side of the servo.
