Originally Posted by TroubleMan
I was thinking about looking into the AE center diff so i could run the 54 spur i just noticed your post about the size issue i don't want to fight with a dogbone problem while gearing is wopping on me also so that would be heaven sent if i could use one. i wanted to know before i headed out to blow some cash is the ae diff gonna use the same bearings or will i have to order some from vbx vxb i can never remember there name.
The AE CD uses the same bearings (8x16x5) so that won't be an issue.
