05.11.2011, 11:16 AM
You need to go up to at least 6mm bullet connectors, and maybe larger. I saw that you are using 10gauge and 4mm connectors. 4mm bullets are not big enough. Plus you need the good bullet styles, like castle sells.
Also, reduce wire length wherever possible. Even an inch here and there translates to alot of un-necessary wire.
Looking good, glad you are having these great results!
