05.11.2011, 11:19 AM
Not sur eif that contacotr will run continous.
Looking at costs, I will try to break down the original trolling motor controller and see if I can remake it in a useable form for this box.
I gave the boat a try again, and it did well. Top speed is pretty good, but I only got a few mins before it started to overheat. I plan to step up the wire sizes all the way to the motor, and try to keep everything as short as possible. Will likely go to 2 batterys, in parallel to help keep the voltage drop to a min.
