05.12.2011, 01:12 AM
If you are worried about the current draw being too much, just put another relay in parallel with each one in the diagram. These relays are cheap - ~$3 each last I looked. It'll probably be a wiring nightmare though!
Good idea! I have a 70 amp model (4 pin) that I can use to turn on the system, and I think I have 4 30amp 5 pins laying around. Yes, wiring will be "interesting, but I can swing it!
