pinkpanda3310
pinkpanda3310's Avatar
05.12.2011, 08:36 PM
If it is 1c charge I will charge just below that rating. For A123's I charge at 10-15 amps. For polyquest 5c 4300mah I charge at 10 amps. Like Brian said, the balance will control the charge rate so they don't stay on those high amps for too long. The polyquest have been slightly puffed but that is from in car use, I haven't noticed any adverse affects from charging e.g. no heat or puffing etc...
