GriffinRU
03.20.2006, 12:08 PM
Originally Posted by virusss
The screw is ok boys, the problem is the motor not spin very free, but is "forced"
400$ of regulator.....puff!!!
290 € of motor.........and is not worked
I mourn my BK XL :(
It is possible that your ESC, when it smoked, overcurrent windings. If the insolation is gone from wires then you will have the same effect on spinning as if you connect motor wires together.
Just a thought, unless you have mechanical problems...
Artur
