_dV
05.13.2011, 03:45 AM
Originally Posted by Nixpus View Post
I have a question: All of the numbers supplied in regards to diff oil... we are talking centistrokes here right? and is that the same as WT? It seems the two terms are used randomly in regards to oils.
wt seems to be a bastardization of the official centistoke unit and varies between companies. some info here
http://www.rcshortcourse.com/forum/s...8332#post28332
The 100K fluid i used was Venom brand and has 100000 on the bottle with no unit.
The 500K fuild i used was Kyosho brand and has 500000 on the bottle and a lot of japanese looking characters :)
The Ofna diff lock lube has no viscosity rating
Likely you will find the 57K centistoke too light if you're after a more constant 4wd feel.
Btw, even with the 500K and diff lock lube you can still turn the diff by hand, it's just rather stiff.
