Jahay
05.13.2011, 06:34 PM
Hi Brian, back in for some help pleaseeee
I am just setting up my castle link on my ice hv160. I am a little unsure as to how i should have it set up???
Under the following settings
Throttle
"Vehicle type" & Specific settings for that type.
Cutoffs
"Current Limiting"
Motor
"Motor Startup Power" - I set for low
"Motor Timing" - did you have normal or low?
"PWM Rate" - what is this? and what should it be set at?
im now running Version 3.26 beta - is that what you are running? or an older version?
Thanks Brian!
Josh
