05.15.2011, 09:16 PM
There are 2 versions of diff & diff case, the newer version of the Tmaxx & emaxx diff uses a different sized bearing on one side, rather than 2 bearings the same- here:
Emaxx 3903/05/08 new style:
http://traxxas.com/sites/default/fil...r_100622_0.pdf
Uses a 8x16x5mm bearing & a 10x15x4mm bearing
Emaxx 3906 / T-maxx 'Classic':
http://traxxas.com/sites/default/fil...nt-pro15_0.pdf
Uses a 10x15(x4mm) bearing on each side of the diff cup.
Im guessing if one of your bearings wont fit then you have the older diff design and a 'new' diff cup- seems that way based on the design of your t-maxx and it's driveline ( old style knuckles and driveshafts etc ).
I would suggest you grab some new 3903/05/08 diffs from ebay to use with your alloy diff cases.
