Originally Posted by squeeforever
exactly, your gearing was WAY to low. thats your problem. actually, to low or high of gearing will make it run hot. so you should have went with a 16 tooth.
that works for motor squee. He is having lipo problems. The 7xl can draw some pretty good amount of current. You may consider falling back to a 8xl. It would help runtime and heat on esc.
