radioman193
radioman193's Avatar
05.18.2011, 01:23 AM
it just helps you in steering and AWESOME for (Drifting)
you let the Gyro do Most of the Correcting as its A LOT faster than you could Ever be.
it keeps you pointed in one direction for the most part.
you can see in the video when it was turned off a few times on the curve the tail would just come up around to the front ....
Plus Under Full throttle takeoffs the rear of the truck would slide one or the other direction it will help keep this to a minimum..
I am not saying that the gyro will KEEP you from spinning out will be a 99.9% improvement .
ALL spin outs START Before one Even starts notice it or See it
and the Gyro is on the job BEFORE you even notice it correcting.
the video is a little drawn out at the start as i had a few people
saying that the gyro would mess with you on a hill or flipping in the air
but as you will see it don't.
sorry about the LOW audio in this Video
the mic on the camera is Under the tripod mount.
will say this it DONT Help you learn not one bit IN FACT it makes it harder for you when you Dont use it After usen it.
and with it you can do things you CAN'T do without it
I dont think there are alot of people here that can take that turn in that driveway at 20+ on lose stones and Holes .
A a human being can not Respond that fast.
Just Fix It !!!
I have been into electronics for 30+ years
and am a licensed Electronics Technician for over 26 years now.
  Send a message via AIM to radioman193
