Originally Posted by MindThoughts
PS. Is it possible to charge a LiPo using the banana plugs, without using the balance plug as well? Reason being- I have some two cell LiPo's that use the two bullet connectors 4mm and the very small 2.5mm I believe it is- bullet connector between the (+ and -) two 4mm connectors. I have a Team Check Point LiPo balancer which only requires I use the banana jacks- from any given charger.
I'm sure I could buy the proper adapter to allow the PowerLab 8 to do the balancing for these older LiPo's I no longer use- but I'm at the moment interested in if this charger will allow me to somehow charge through the banan jacks only- Any insight will be greatly appreciated.
I think I know what you are talking about and yes, you can make all sorts of adaptors.... Or you can buy something like this:
http://www.amainhobbies.com/product_...llet-Connector
A Main has all kinds of adaptors that might work for your situation. The Monster even has one for Hyperion Charges that you could modify:
http://www.rc-monster.com/proddetail...LB10CAR&cat=19
