BIG-block
05.21.2011, 11:17 AM
Originally Posted by Unsullied_Spy View Post
Watch temps and don't push it to it's max speed and it should be an absolute animal. Patrick said a while back that they're rated to 45,000 RPM because the magnets will start coming apart at higher speeds. I've run this motor on 4s and 6s and it's stupidly powerful in a very heavy 1/8th scale Truggy, 8s would push a 5th scale pretty well if you were smart about your setup and watch temps. Main problem I see with running it on 8s is accidentally over-revving it, I'd stick to 7s max myself.
Hmmmmm, I think you are right about 7S but I want to fit this setup to a Savage flux and fit one 4S batt on both sides. Going to 7S might cause bit of a imbalance. That is the main reason why I wanted to go with 8S. Wouldn't be nice if the MMXL had a rpm limiter. You just dial into the CC Link what your motors safe rmp is and presto, can't over rev it.
Being a such a over powered rig it will be doing a lot of back flips and spending a lot of time in the air with a fair bit of throttle input for flipping and correcting during flight. This is where I see the over reving becoming an issue. I would hate to destroy one of these motors before Castle starts to make something similar again.
