sikeston34m
sikeston34m's Avatar
05.21.2011, 11:27 AM
Originally Posted by BIG-block View Post
Hmmmmm, I think you are right about 7S but I want to fit this setup to a Savage flux and fit one 4S batt on both sides. Going to 7S might cause bit of a imbalance. That is the main reason why I wanted to go with 8S. Wouldn't be nice if the MMXL had a rpm limiter. You just dial into the CC Link what your motors safe rmp is and presto, can't over rev it.
Being a such a over powered rig it will be doing a lot of back flips and spending a lot of time in the air with a fair bit of throttle input for flipping and correcting during flight. This is where I see the over reving becoming an issue. I would hate to destroy one of these motors before Castle starts to make something similar again.
Why couldn't you limit the throttle to about 90% in the ESC setup?
What you will find is going to be an insanely overpowered beast anyway.
