Adapters To Modify To Fit The PowerLab 8 Balancing Ports.
MindThoughts
Adapters To Modify To Fit The PowerLab 8 Balancing Ports. - 05.24.2011, 02:49 AM
Yikes-
I didn't see this post-
Thank you for the information. To this day- I've not modified nor made my own balancing adapter plugs- though I'm very interested in how to do this. Though I would need to be certain I would not damage the charger nor any of the cells in the battery. The RC Monster balancing adapter plug(link to- in your post) looks like it may plug right into the PowerLab 8- if not- maybe I can find a way to make this adapter work- by replacing the end which plugs into the charger- with the plug which fits into the PowerLab 8 balancing port.
I think I know what you are talking about and yes, you can make all sorts of adaptors.... Or you can buy something like this: http://www.amainhobbies.com/product_...llet-Connector
A Main has all kinds of adaptors that might work for your situation. The Monster even has one for Hyperion Charges that you could modify: http://www.rc-monster.com/proddetail...LB10CAR&cat=19
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
