Dj_Sparky
05.24.2011, 10:04 AM
Originally Posted by Bmr4life View Post
Boring head with a set of boring bars.
http://ttv.mit.edu/tags/331-to/video...machine-shop-7
A boring head is about $60 and a set of bars is $20 or so.
This is usually used on a mill, but can also be used on a drill press. With this, you could use just one piece of aluminum since you can control the dept of the hole. This is what I plan on using.
Will do that.
By the way, do you know of some metal cutting/types of metal tutorials? A tutorial on metal or something. Basically I would like to know more about how to work with metal, and cheap tools (Tools not ranging in the 10.000$++ range.)
