Thank you for the detailed information, and links.
MindThoughts
Thank you for the detailed information, and links. - 05.25.2011, 05:56 AM
This is fantastic information. And thank you for the links as well :-)
PS. Once you've create your own balancing plug adapter- please do post pictures of the plug. And if possible- also post pictures of the process of parts you begin with- and what you change- or modify to make it suitable for your specific application. Thank you again :-)
If you read the manual there is somewhere in there that talks about the pinout config. BrianG has a area on his site that might help you understand how a pack is wired. http://scriptasylum.com/rc_speed/lipo.html
I have to pick up a 2mm bullet and then I will make an adaptor too. I will take some picks when I build the adaptor. It probably wont be for a few weeks though.
This is what Im going to use to do a custom adaptor:
http://www.amainhobbies.com/product_...xtension-Cable (Im going to chop off the end and get rid of the extra wires)
and
http://www.amainhobbies.com/product_...ana-Plug-Cable
and
http://www.amainhobbies.com/product_...-Male-2-Female
and
PS: I saw your post on RC Tech, just get a slipperential....
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
