ta_man
05.29.2011, 09:19 AM
Originally Posted by josh9mille View Post
I just got done scan-reading the entire thread up to page 16. Those guys sure are skeptical of the way he did the test and are all saying he should have done it differently. And whoever mycrors4 is seems to be a MA fanboy and does not know what he is talking about. He says its no big deal if a pack puffs up and that he has never heard of a MA pack failure. He must be in his own little world or something.
To some extent I believe the skepticisim is justified. He said it was a constant 30 amp discharge then later went on to say he used a string of light bulbs as the discharge load. That will not result in a constant load as the voltage decreases.
Not to say the results would be different with a true constant 30 amp load, but when your technique is off, it can call into question other aspects of the test.
One would figure with all the stuff he does, he would have had a discharger capable of constant current discharge (like a Turbo 35 or a Tekin DIS-350).
