06.02.2011, 11:05 PM
i would definitely recommend the 1410 on 3s over the 1406 5700kv on 2s. also, the 1410 is more motor than the 1406 despite the same can size, so it would be able to handle being geared for higher speeds without heat issues.
they both run MUCH cooler than the cm36 motors. i run my 1410 in a 6-7lb very heavy crt .5 geared for 55mph on 3s and that motor stays at 120-135F after a hard run.
