slimthelineman
slimthelineman's Avatar
06.05.2011, 11:14 PM
It is hard to fathom runtimes like posted above, but with lower current draw the same packs will run much longer. Not sure how long my rigs run. Typically get six minutes with a warm up and the five minute heat but using some numbers (600-700mah for the ebuggy) should be able to run hard for around 15-20 minutes on a 6s 2650 40c with my 1400 kv motor.
Nothing is simple but it's easy to remember that the less current you are using be it spikes or avg. The longer yo can run for a given capacity compared to a lv high current setup. By the way, great discussion so far. Lots of good stuff.
