Jahay
06.08.2011, 06:36 AM
Thanks for the comments guys!!! yes it is definitely performing, and seems to handle nicely... Im just going to stiffen up the front suspension slightly as it is sagging a little.
Sparky - haha 1717??? nonono... im usinig the 1520 1600kv... im pushing it just over its limit on 9s at 4.2V at 63000rpm... We will see how it holds out... obviously im expecting premature wear etc... but its all a bit of fun.
NUZ! I KNOW RIGHT! been a very long time! I think you are right though... i may need to run a plastic spur with a steel pinion just to reduce the wear and strain on the pinion.
I cannot just go for any old centre diff though... i need one that has very tough internals and an alloy case...
I wish i could run a huge spur gear, but it isnt possible as it may not fit under the diff top plate... so what is a very strong, durable plastic spur available with a decent alloy case and strong internals???
More vids to follow as soon as the new pinions arrive :)
