nuz69
nuz69's Avatar
06.08.2011, 07:52 AM
Plastic spurs are larger than steel spur. And as your spur/pinion mesh is protected against dust and small rocks under the chassi, the spur should be relatively durable ?
Given the weight of the truck and the power inside ... hopefully it was just bad luck !
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
