brian015
brian015's Avatar
06.08.2011, 11:19 AM
Brian, i have just ordered two pinions so ill go through those first... but if i go through a pinion everytime i run the truck, then something needs to be done about it....
What gearing do you use brian and do you have problems with pinion or spur wear???
I've run a few different pinions. One of them broke the first time out - I attribute it to a defective pinion, because the others have held up fine for many runs. Last summer I used the same 20t pinion all summer long - it showed some wear, but nothing out of the ordinary.
