Jahay
06.08.2011, 11:19 AM
Hmmmm if i can get a 52T Mugen centre diff and then run an 11t pinion... i should most probably be ok... Im going to have a look at them... hopefully they are thicker than metal diffs... so the contact surface area is increased.
Brian! You use a 20t pinion? What spur size are you running? i know you are using a lower kv motor, but 20t! Thats huge!!!! if i geared a 20t pinion, i would be over the 110mph barrier haha
