Hyper-5
The-Hyper One
Hyper-5's Avatar
06.11.2011, 11:15 PM
Depends, you can always the larger, lower kv motors higher as they generate more torque.
Joe Ford used a 1512 2650kv motor on 6s and hit 100mph easily, so any which is 4 pole and roughly that size & kv should work fine- it will be easier to gear the higher kv motors high enough though, compared to the lower kv motors.
does he hav a vid up on it? atm my buggy weighs with only 1 11.1v 3.5kg (7.716 lbs)
