06.17.2011, 08:16 PM
I don't think it's the Neu-Castle 4-pole design. Looks more like the older 2-pole CM36 Castle motors, before they updated to the rebuildable style. HPI had a system just like that OEM'd by Castle, their Motiv/Warp combo.
It says 4 pole in the description:
The 4-pole, 3900kV sensorless brushless motor delivers more torque with greater efficiency, to meet the demands of today's off-road vehicles.
Motor Specifications:
Dimensions:1.42 x 1.85 in (36 mm x 47 mm)
Weight (w/wires):6.54 oz (185.4 g)
kV (RPM/V):3900kV
Voltage Input:2S MAX
Shaft Diameter:0.125 in (3.175 mm)
Poles:4
Wires:13AWG Silicone, 6.89 in (175 mm)
Connectors:4 mm Male bullet connectors
The 1406 motors measure 36x49mm vs 36x47mm for this motor, so my guess is also that its a cheaper variant made to Duratrax specs, like the HPI Flux 2350kv motor which is a 1517 with cheaper magnets- not a bad little system for $100..
