scarletboa
scarletboa's Avatar
06.20.2011, 04:32 PM
believe it or not, when i first started soldering, my solder joints were worse than those ones. was using a 40w corroded soldering iron with cheap lead-free solder. i ended up getting a radioshack 230/150w soldering gun and some good old fashioned 60/40 lead solder and some flux paste. now, my solder joints look like they were done from the factory. the quality of your soldering mainly depends on 2 things: materials that you use and amount of practice that you have.
i would definitely revise those solder joints before trying to rule anything else out on your setup.
