BIG-block
06.21.2011, 07:06 AM
Originally Posted by Hyper-5 View Post
na, it just happened yesterday for the first time, l'll solder the other part and hopefully all back to normal, still thinking about getting the 2650kv castle with 22.2v ;)
Don't do that. You will just kill another motor. If you want to run 6S stick to the CC 2200kv motor and be done with it. With right gearing and decent lipos (you already have a good ESC) you should be pushing 75mph+ easily and have a reliable, fast buggy. 2650kv motor will run hotter and on 6S it will be around it's maximum safe RMP. Not a good thing if you want your motor to last a while.
