thzero
06.21.2011, 04:07 PM
Yes you will. I'm not even sure that the 1717 will fit length-wise with the TCS TVPs. The 1520 should be able to be mounted with a bit of grinding for to account for the length over the motor over the stock.
You can always grind out the Flux mounts to fit either the 1520 or 1717. I've got the GCM mounts for a 1520 as I was planning on mounting this up, but ended up putting it in my truggy.
Originally Posted by NickRummy View Post
I want to run a 1717. I've been reading up about the Alza mounts for them. What do you guys think about using these mounts with the TCS TVPs? I have a 1520 right now but bigger is better right? .
FYI, I'd just go ahead and get the bulletproof Flux diffs, you *are* going to break the standard diffs very quickly.
