drivers stand
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
drivers stand - 06.23.2011, 11:29 AM
I am still contemplating driver's stand ideas. The problem is that the stand location ideally is in the middle of the yard, so a portable stand would be best, though it also needs to be steady. In my mind, the stand would have a drive-up ramp to a driver accessible pit area for battery swaps, etc. from the driver stand(driver does his own pit stops). Shade from the sun(sun will be behind the driver) would be ideal as well.
So, making a steady, shaded, driver-pittable, and movable stand is the goal - not so easy, unfortunately. I will keep mulling it over while i build out the track.
And Harold - I won't allow the stand to mock you if you ever roll into my neighborhood and use the track - maybe we can make up/fabricate some kind of a wheelchair stand that you can anchor to - we can put it in the bucket of the tractor and lift you to your desired height! Just be nice and don't yell at the marshalls while you are up there or it may be a long night!
