simplechamp
simplechamp's Avatar
06.26.2011, 06:06 PM
If you want to run the 1409 in a 1/8 buggy-based chassis consider getting a lower kv and running something like 6S 2200-2600mah. It will help keep the current draw low and keep the temps down on the smaller motor. If you want to run 4S consider the Castle-Neu 1415 2400kv and MMP combo. You can dial back the power with torque and/or punch control if needed.
