03.23.2006, 07:52 AM
hi there, first off, do you have a heatsink motor clamp? This will reduce temps, also , and fan on top of the motor will cool it down some. Gearing it down WILL NOT reduce temps, gearing up will, if you get a 7xl , you can get similar top speeds as your 8l, all you do is gear up . Hope this helps
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
