Batfish
Batfish's Avatar
03.23.2006, 08:51 AM
Originally Posted by squeeforever
Welcome to the forums. You will like it here and im sure you will learn alot. As for the chassis, well, there isnt much you can do. AE makes some kind of clear protective film that a few poeple on the forum use but im not sure were to get it.
The Team Associated chassis protection film is actually very good. You can cut it to fit just about any situation and the adhesive holds it on well.
http://www.teamassociated.com/enlarge/6312.htm
When used on the bottom of an off-road 1/10th vehicle, it can keep the chassis underside looking like new forever :)
Joe
