Originally Posted by BMW318TI
More news about this problem?
There is no 'problem'- read the previous posts. Certain revisions of the castle esc don't react well to certain firmware updates due to different hardware being used inside the esc wiht each revision.
If you try a version of firmware which causes the esc to behave strangely ( like low throttle stuttering for example ), then try a different version of firmware until the 'problem' stops = problem solved. There is nothing wrong with the esc, and nothing wrong with most of the firmware version as such- it's just an unfortunate coincidence that firmware and hardware don't always play nicely together.
Originally Posted by thzero
Thomas,
I have two that are v3s (I believe?), one demonstrated the issue and the other didn't (actually you guys should have the one that didn't as I sent it in for repair work). How can we tell which version is which and is their minor revisions within a version?
Easy, when you know how:
http://traxxas.com/forums/showthread...00022-Firmware
Post 28 onwards
