07.05.2011, 12:19 PM
The little O-rings will actually make it feel a little tighter. I have built the Slipperential with and without them. Without them, an extra shim behind the small internal gears may be helpful. If the notch is due to a slightly lose mesh, the extra shims will help(Mugen shims again should work here as well).
