07.06.2011, 04:07 PM
Are you looking for fairly simple parts like a chassis or other basically flat parts? If so, you could get a CF sheet and "machine" it pretty easily with a dremel to the shape you want. A dremel cutting wheel, side cutter bit, and sanding wheel will let you cut pretty much anything you want within reason. It's pretty easy, but a bit messy - and definitely wear a dust mask.
