_dV
07.08.2011, 08:59 AM
Originally Posted by rcanka View Post
Also the shock tower support is an AWESOME idea, what did you use for it?
The tie rods ends are standard Savage Flux tie rod ends. Joining them is a cheap m4 bolt. m3 bolt cut to size holds it to the chassis. You also need a longer shock bolt, think I used the same ones that go through the top of the roll bar.
47 spur with a 20 pinion will be about the same as the 44 with a 19 pinion. you might need to gear a bit lower then that. just keep an eye on your motor temps.
