_dV
07.08.2011, 08:40 PM
Originally Posted by rcanka View Post
Thanks again, dV.
Will gearing like 16/47 give me more or less controllability in the air?
This is a difficult one to answer. Simple answer is that more than likely you will have less control. This will be because even though you will have heavier trenchers you won't have enough top speed to generate a decent change in angular momentum once your get into the air (for rotating backwards).
6S will probably make this less noticeable than 4S though with a 2200kV. 16/47 is very low gearing, total reduction is nearly 21.
Differential Ratio: 3.2222222222222223
Transmission Ratio: 2.215277777777778
Spur Tooth Count: 47
Pinion Tooth Count: 16
Total Voltage: 22.20 (6S)
Motor KV: 2200
Tire Diameter (inches): 6.3
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 20.96822 : 1
Tire Circumference (inches): 19.79 inches (502.72 mm)
Rollout: 0.94:1
Vehicle Speed: 43.66 mph (70.13 km/h)
