Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
03.23.2006, 06:16 PM
I've always been told 2 pole motors don't like much timing - to be honest I've only tried more than 6 degrees timing on a motor once, on a 540 6s, and it didn't much like it - it ran hotter and lost some bottom end, maybe because my batteries. Will experiment a bit tomorrow though.
Maybe Mtroniks set 12 degrees timing from the factory, and this is why I felt a small loss in power when I set it to 0? Didn't know BK set such high timing by default.
16/66 is about 20:1 in 2nd gear? The tyres are stock (5.75 inch), the motor assuming the battery voltage doesn't drop too badly (gp3700's) will be turning ~40,000rpm, which ends up around 33mph? The gearing I'm on now is 37mph by the numbers. This isn't unreasonable? My friends emaxx with stock electronics on 7 cell gp3300 packs must be doing 30mph easy.
The emaxx is 95% stock so stock weight..not too sure exactly to be honest.
  Send a message via Yahoo to Rtsbasic
