RCX fundraiser with the World Motor Sports Breast Cancer Foundation. Please read through the next few posts to see the 42 Prizes worth well over $12,000 associated with the Fundrasiser Giveaway.
Prize Package #1
Valued at nearly $4000
Prize Package Consists of:
Baja Modifiers: HPI Baja 5SC 1/5th Scale Truck
TGN/LSN: Easy Grab Carb Needle, Billet Carbon Gas Cap, DT1 Tripple Flow Air Filter, TGN Track Pipe Nickle Finnish
Team Chase: Axle boot Protectors, Carb Diaphram Filter, Rear Shock Tower Supports
Woodster Lidz: Woodster Wide Body
Thunder Designs: Custom Wrap on Woodster body
DDM: Dominator V2 Pipe Chrome
Igloo Racing Products: Front Bumpers and Chassis Brace
Vertigo Performance: 17T Hex Drive Pinion Gear, 18T hex Drive Pinion Gear, 9mm Rear Axle Extenders, Adjustable Clipless Front Axle Extenders, Hex Drive Clutch Bell, Vented Clutch Carrier/Cover, Vertigo T-Shirt, Tripple Brake with Alum Caliper, Tranny Imput Shaft Carrier Alum
DarkSoul Racing: Spring Adjuster Nuts, Spring Perchs, Servo Saver Alum
Turtle Racing Products: Front and Rear Alum Shock Towers
FullForce RC: Fuel Line Kit, Sway Bar Mounts, Servo Clamp Set, Bearing Set
RCP: TT Wide Body
CraftWerks-RC: TT Wing Nuts, Billet Spur Gear Carrier, Tail Lights, Billit Body Pins
Kraken RC: Ti Shock Shafts
Outerwears: Custom Printed Shock Covers, Air Filter Pre-Filter, Pullstart Filter
Dog Pile Racing: $100 Gift Certificate
Hostile Racing Products: Set of 4 Tires, 2 Spur Gears 56t and 57t
Huge Thank You to all of these Great Companies for Sponsoring the RCX Chicago World Motor Sports Breast Cancer Foundation Fundraiser!!!!!!
To be entered into the RCX Special Giveaway occurring at RCX Chicago on August 6th simply make a finanical donation the World Motor Sports Breast Cancer Foundation. This can be done Live at the Show at the Foundations booth or through the Air Age Media Store
http://www.airagestore.com/rcx-donation.html.
For Every $5 you donate RCX will give you 1 entry into the Special Drawing. Donate $20 get 4 chances!!!
This is the first of many Special Giveaway prizes to be listed, check back often for more updates and prizes!!!!
Drawing to occur around 6:30pm August 6th at the RCX EXPO
